Does latch require setup time before rising edge?
Discussion in 'General Electronics Chat' started by dMoser, Jan 24, 2012.
  1. dMoser
    Aug 25, 2011
    30
    I learned that setup time for latches is the time before clock's falling edge in which data needs to remain stable.
    Say that just as clock's rising edge arrives, data become stable, will Q become valid after Tpdq?
    Thanks.
  2. Brownout
    Jan 10, 2012
    2,375
    998
    That depends on if the latch captures data on the rising or falling clock edge.
  3. dMoser
    Aug 25, 2011
    30
    This is a transparent latch, meaning it passes data when clock is up.
  4. Brownout
    Jan 10, 2012
    2,375
    998
    In that case, I'd say yes. Best to verify with the datasheet though.
  5. MrChips
    Oct 2, 2009
    12,652
    3,461
    You need to specify the part number.
    If it is a transparent latch that latches the data on the falling edge, e.g. SN7475, no setup time on the rising edge is required. Setup time for SN7475 is 20ns prior to falling edge.
  6. Brownout
    Jan 10, 2012
    2,375
    998
    On second thought, there might be a different time specification from clock to Q-Data. That's why you need to verifiy with the datasheet.
  7. dMoser
    Aug 25, 2011
    30
    Thank you guys!
