recklessrog
- Joined May 23, 2013
- 985
maybe it would be worth trying to connect the batteries differently. One from bottom left to top right, the other bottom right to top left! (eeeermm)
Lithium, or standard lead?Two car batteries would work.
Which is more explosive?Lithium, or standard lead?
Understandable. Happens to me all the time.....Honest mistake man, I just forgot about current.
...this could work too somehow...
Remind me to call my broker. I need to buy a block of multimeter futures.I'd start looking for a multimeter supplier that offers volume discounts
C'mon, alfacliff. You know magicians are never supposed to give away their secrets! Now I gotta sell my multimeter futures at a discount.the origional diagram just has two batteries shorted out connected together.current would flow between + and - on each battery, and theres no circuit for current to flow in the middle wire.
Now that I think of it... lithium would be a better choice... it can also be turned into pills, you know... which might be in desperate need in this caseWhich is more explosive?
Fair enough... here's my attempt to be of some help in this thread. Have a look at this, and read it carefully.ive had enough. u guys pull the piss too much and dont help.
There is a circuit through the wire, from the - of one to the other +, and vice versa, so it actually flows both ways through the bottleneck, hopefully giving me the subtracted volts. (according to me ADDING RESISTORS NEXT TIME!!! -at both negatives in both batteries.)the origional diagram just has two batteries shorted out connected together.current would flow between + and - on each battery, and theres no circuit for current to flow in the middle wire.
by Aaron Carman
by Jake Hertz
by Aaron Carman
