Does anyone know of a small IC package for a "momentary latch"?
Discussion in 'General Electronics Chat' started by durable126, Feb 28, 2016.
  1. durable126
    Feb 20, 2016
    56
    Does anyone know of a small ic package for a momentary latch?
    For a momentary switch to turn something on and off
    I know how to use one using bits, but would rather not have the headache
    I have not found any ready made IC out there but I'm sure someone makes one.
    anyone know of any?
  2. durable126
    Feb 20, 2016
    56
    I should clarify, small meaning 8 pin dip package area, does not need to be smt
  3. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    A momentary latch AKA: a monostable - you can make that with a555.
  4. durable126
    Feb 20, 2016
    56
    a latch for a pushbutton switch to turn something on and off
    as opposed to a slider or toggle switch
  5. ian field
    Oct 27, 2012
    4,447
    791
    That's a bistable, some manufacturers are producing individually packaged logic gates - there may also be individual flip-flop logic elements.
    Or you could use 2 transistors and a handful of components.
  6. durable126
    Feb 20, 2016
    56
    That is true but i was trying to avoid having so many parts
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I don't think such a part exists. AFAIK there have been very few new MSI IC's introduced since the late 1980's. Everything now is FPGA and microprocessors. So how about an 8-pin ATTiny and a few lines of code?
  8. absf
    Dec 29, 2010
    1,493
    374
    If you dont mind SMD package, there is at least one....
  9. Lindembruck
    Member
    Feb 28, 2016
    32
  10. Lindembruck
    Member
    Feb 28, 2016
    32
  11. pebe
    Oct 11, 2004
    628
    As Ian suggested, use a 555.
    Connect pins 2&6 together. Fit a 10k resistor between those pins and V+.; that keeps the latch normally off.
    Connect a momentary push button between pins 2&6 to V-.. The latch will turn on for as long as the button is pressed.
  12. AnalogKid
    Aug 1, 2013
    4,686
    1,297
    To turn a momentary pushbutton switch into an alternate-action function, you need a little debouncing and a toggle flipflop. Depending on the circuit voltage, you can use 7400 series TTL or 4000 series CMOS 14-pin chips. With the CD4013 you get two toggle flipflops in one package. There are specialized ICs for LED flashlights that are a single toggle ff in one SMT package, but you usually have to buy a large quantity.
    ak
  13. Lindembruck
    Member
    Feb 28, 2016
    32
    The NC7SV74 pdf linked above looks be what do you want!
  14. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    There is even a smaller one 1G80.
    Bertus
    AnalogKid and absf like this.
  15. BillB3857
    Feb 28, 2009
    2,402
    348
    ErnieM and Lindembruck like this.
  16. TheButtonThief
    Feb 26, 2011
    219
    38
    Maybe the OP has a specific switch/button that they would like to use and so switching function needs to be designed.
    My choice would be to use a µc, the ATtiny85 is an 8 pin package and is also available in SMT. The regular package is the same as a 555 but wouldn't require any external components, just an embedded programme.
  17. ian field
    Oct 27, 2012
    4,447
    791
    That's the sort of thing I was thinking of.
    Just wire not-Q back to the D input and the output changes state on every CP transition.
  18. durable126
    Feb 20, 2016
    56
  19. Lindembruck
    Member
    Feb 28, 2016
    32
    Hi!
    In this link, we have a lot circuits.
    I think, you will can use a Darlington in the flip flop output with a resistor but you need to upload pictures and the flip flop you have with the schematic you has tried.
  20. AnalogKid
    Aug 1, 2013
    4,686
    1,297
