Does anyone know Iron Vane?
Discussion in 'General Electronics Chat' started by chudiandeyu, Nov 5, 2010.
  1. chudiandeyu
    Oct 26, 2010
    36
    I saw Iron Vane is also a kind of current probe, but when I am using an iron vane do I have to open the circuit? Or it is just like current transformer could directly measure it?
    Thanks!
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    From the wiki:
    here is the full page:
    http://en.wikipedia.org/wiki/Current_clamp
    Bertus
  3. chudiandeyu
    Oct 26, 2010
    36
    @bertus
    But in wiki it does not say how to use it...
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  5. Kermit2
    Feb 5, 2010
    3,846
    963
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  7. chudiandeyu
    Oct 26, 2010
    36
    @bertus
    Thank you
  8. marshallf3
    Jul 26, 2010
    2,358
    201
    I'm familiar with these, they were commonly used by auto mechanics as high current ammeters, matter of fact I have a set of them from Snap-On down in one of my tool boxes.
    On an active (closed) circuit you lay it against the current carrying conductor and the vane would move to indicate the amperage. One of mine is a low range (used to test charging current and alternator field winding draw) and the other is a high range used to test starter motor current.
    They didn't have to be clamped around the wire, just put on top of a short length that was flat.
    Very handy devices in their day, still handy even now.
  9. debe
    Sep 21, 2010
    955
    185
    The bottom Meter is what marshallf3 is refering to, Is used by placing on wire & reading current of Altenator or the higher scale for startermotors. The Volt meter is a moving vane in a coil & will measure AC or DC. Daryl
  10. marshallf3
    Jul 26, 2010
    2,358
    201
  11. chudiandeyu
    Oct 26, 2010
    36
    Hello marshallf3
    You mean just lay the Iron vane meter besides the current carrying conductor then it could indicate the current? without any connection?
    Thank you.
  12. debe
    Sep 21, 2010
    955
    185
    Hi chudiandeyu, Yes you just place the meter on the single wire you want to measure the current on, DC only. Daryl
  13. chudiandeyu
    Oct 26, 2010
    36
    Thank you Daryl
    So iron vane cannot measure AC current?
  14. debe
    Sep 21, 2010
    955
    185
    There are diferent types of iron vane meters, picture of an AC/DC moving iron Ampmeter showing a 240v electric jug hooked up to it. Daryl
    chudiandeyu likes this.
