Does anyone know if something like this exists?
Discussion in 'The Projects Forum' started by patrick99e99, Sep 2, 2013.
  1. patrick99e99
    Aug 19, 2013
    17
    So this is a drop target bank... The four black plastic rectangles have springs attached to the bottom, and when they are raised up, they hook to the ledge (the black long plastic piece at the top with the 5 screws on it).
    I am brainstorming, looking for a way that I can cause a target to fall down through electronics........ I am imagining some kind of miniature coil, that is be somewhat flat, until current goes to it-- and then it would raise up a tiny amount (1/8" or something), and that would cause the target to get pushed off the ledge, so it can fall down.
    I was originally looking for tiny solenoids, but all of those were too big to fit on this--- So I just thought I'd ask here if anyone knows off the top of their head something that could be used to accomplish this?
    Thanks!
  2. #12
    Nov 30, 2010
    16,663
    7,310
    I read something about really tiny fans. Not rotational, more like flapping a bird wing. Searching my memory, not getting much. Maybe a piezo element with a lever...
  3. tracecom
    Apr 16, 2010
    3,878
    1,396
  4. John P
    Oct 14, 2008
    1,637
    225
    Simply passing a current through a wire, to cause it to heat up and stretch?
  5. #12
    Nov 30, 2010
    16,663
    7,310
    Is muscle wire repeatable? (keep repeating the same motion just because electricity is applied?)
    Never mind. I just found the reference.
  6. tracecom
    Apr 16, 2010
    3,878
    1,396
    That's my understanding, but I don't have any first hand experience. Maybe I should order some; looks like fun stuff.
  7. Sensacell
    Jun 19, 2012
    1,183
    276
  8. #12
    Nov 30, 2010
    16,663
    7,310
    It might be good enough for an eighth of an inch...
  9. Metalmann
    Dec 8, 2012
    700
    223
    Usually, metal expands when heated.?
  10. #12
    Nov 30, 2010
    16,663
    7,310
    The "trick" about muscle wire is that it resumes a previously applied shape when heated.
    Metalmann likes this.
  11. sirch2
    Jan 21, 2013
    1,008
    351
    A Piezoelectric actuator?
