Does anyone know any alternative for DM9368/9370/9374
Discussion in 'General Electronics Chat' started by Omar123, Jan 4, 2013.
  1. Omar123
    Dec 23, 2012
    36
    There 3 IC's are the same IC.it's a BCD to hexadecimal decoder that drives a common cathode.Here is the datasheet incase u need it.
    http://pdf1.alldatasheet.com/datasheet-pdf/view/51130/FAIRCHILD/DM9370/+_1Q42UwYhRDpKxHeIThwhz+/datasheet.pdf
    Now since this IC is obsolete(discontinued) and can rarely be found and a bit expensive. Can someone recommend me any alternative other than the MC14495 or a PIC or anything programmed since I need an IC
    I need something fresh and new to the market.
  2. SPQR
    Member
    Nov 4, 2011
    379
    48
    Check out THIS thread from the forum here.
    There are two or three possibilities.
    Omar123 likes this.
  3. BillB3857
    Feb 28, 2009
    2,402
    348
    First, according to all the data sheets I found, the ICs you listed are BCD to 7 Segment decoder/latch/drivers, not Hexadecimal decoders. In most cases the 7 segment decoder ICs available now will require pin reassignment, but will work. Have you tried a GOOGLE search for "bcd to 7 segment decoder"?
  4. Omar123
    Dec 23, 2012
    36
    Thank u for your reply SPQR have solved my problem
