I'll try to explain what I'm doing:
I was using a 556 as a flip flop for a single button push button start for my car.
The original design works but in the interest of having way fewer parts and because I'm a glutton for punishment, I found an EDE2208 which is a momentary-to-toggle IC. It seems like a perfect solution and even has switch debounce built in.
Only one issue, and it actually might not be an issue: Because this is in a car I need to keep my at rest parasitic current draw to a minimum.
I was planning on using a 5V + regulator powered all the time, but that's where my issue or concern is. Will a 5V voltage regulator draw an excessive amount of current if the 2208 is inactive or not powering/controlling a transistor?
While I'm on the subject, could anyone recommend a good all purpose 5V + regulator? I was thinking a 78L05 would work, but the spec sheet is listing it maximum quiescent current as 5mA, it would be great if I could get it down more.
I'm only going to be using 1 set of contacts, so I won't be over-working the regulator too much, right?
Thanks for the input,
Dan
Dan
