invaluable?using such a powerful tool as LTspice is has been extremely invaluable.
I think either you or your translation software make an excellent point.
ak
Has simulation made us dumber?
Collectively, I think a strong argument can be made that both have -- as have many other things. Increasingly people can't navigate around their own city, let alone take a cross-country trip, without a GPS. Give them a street map or, heaven forbid, just give them a street address, and they are completely lost (literally and figuratively).Have calculators made us dumber?
No, you can't. The best you can hope for is useful qualitative definitions. You are using a tool too much when you become reliant on it to do things that you should be able to do yourself. When you HAVE to use a calculator to multiply 7 by 9, you are using it too much. Now, the next question will be whether or not you can have a precise definition of what you should be able to do yourself and, again, the answer is no. In that sense it's the same as looking for a precise definition of what is and isn't "art" (which is probably simple in comparison).They're just another tool. BTW how much is "too much"? Can we have a precise definition -- puhleeze!?
This is one of those oddities of English (and I imagine many other languages have similar examples, but English is likely the worst). The prefix in- is usually considered to mean "not", so you have fertile and infertile, for example. But in specific cases it either has no effect on meaning or it is used to indicate "to a high degree", so you have flammable and inflammable, which mean exactly the same thing, and you have valuable and invaluable in which invaluable means so valuable that the value can't even be stated.invaluable?
ak
Way too simplistic.If you can convert your requirement into a formula you can build it.
God, I envy you...I don't simulate, except between my ears. Then I build.
Ouch!... no, I don't use a translation software. Never had it, never will.invaluable?
ak
I don't need advice on when to use them and when not to use them and I was prodding the TS/OP for his opinion. I know what your opinion is already as well as many of the other frequent posters. For those trying to decide on how or when to use them I think it is prudent to become familiar with them. I would not want to dissuade anyone from learning about them. Similarly I would not want to dissuade anyone from building a few and testing a few before building a lot.No, you can't. The best you can hope for is useful qualitative definitions. You are using a tool too much when you become reliant on it to do things that you should be able to do yourself. When you HAVE to use a calculator to multiply 7 by 9, you are using it too much. Now, the next question will be whether or not you can have a precise definition of what you should be able to do yourself and, again, the answer is no. In that sense it's the same as looking for a precise definition of what is and isn't "art" (which is probably simple in comparison).
Mmhhhh.... it seems that I did not make a mistake after all:invaluable?
ak
Or maybe pointing out that 'invaluable' can't be modified by the adverb 'extremely'?Mmhhhh.... it seems that I did not make a mistake after all:
http://www.merriam-webster.com/dictionary/invaluable
So I'm taking it you were twisting my words to make an ironical point?
There's another one where someone figured out how to do math when pen and paper and it was classified as a high military secret because of the potential advantage it would give if the computers were taken out.I remember reading a science fiction short story set in the future where the character was brought up on heresy charges because he claimed he could do math in his head but everyone knew that only machines could do math.
by Jeff Child
by Duane Benson
by Duane Benson
by Duane Benson
