Do ovens require special light bulbs?
Discussion in 'General Electronics Chat' started by droggie, Jan 23, 2013.
  1. droggie
    Oct 21, 2012
    137
    The lightbulb in my oven has been out for some time. I just checked the bulb and it says 40W 120V JC Appliance. Are these bulbs specially built for ovens and are they easy to come across?
  2. MrChips
    Oct 2, 2009
    12,657
    3,461
    Yes. Any hardware store should have appliance light bulbs.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    At least in my country they are quite common. Find then im most larger food stores. That also sell light bulbs. But you are correct that they are specially built for ovens. They have work in the high temperature environment
  4. GopherT
    Nov 23, 2012
    6,340
    4,094
    They are made so the base does not corrode (and get stuck in side the socket) and higher temperature solder formulations are used (bottom center electrode) to allow service in excess of 1000F (550 C) for self-cleaning ovens. The bulbs cannot be on during the cleaning process but the metals exposed to those temperatures survive. It is also recommended to use these appliance bulbs in non-self cleaning ovens because the glass is thicker and is less likely to break during installation/removal since you can access only the crown of the bulb when turning it for most ovens.
  5. droggie
    Oct 21, 2012
    137
    I went to a hardware store today and the most common type of appliance bulb is a frosted type. It looks similar to the one I have. But my original bulb calls for 120V, where the one in the hardware store calls for 130V. Is this hazardous?
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    No, it isn't dangerous. It will light a little more dimly but last a lot longer.
