Do-It-Yourself Soldering Station with an ATmega8
Discussion in 'General Electronics Chat' started by Dr.killjoy, May 13, 2016.
  1. Dr.killjoy
    Apr 28, 2013
    1,209
    157
  2. dannyf
    Sep 13, 2015
    2,196
    417
    I didn't build that one but have built countless others, using some lowly 8pdip mcus and they have always worked as expected.
    no need for pid actually.
    Dr.killjoy likes this.
  3. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    The only reason I asked cause I have a broken Hakko 939 and it has a nice transformer for a new soldering iron build.
  4. tracecom
    Apr 16, 2010
    3,878
    1,396
    I think the concept is sound. However, I would be inclined to try to fix the Hakko. What are its problems?
  5. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    The unit works perfectly but the case broke.. I tried finding a suitable case but never found one ..So I just bought a Hakko FX-888D soldering station..
  6. Dodgydave
    Jun 22, 2012
    5,142
    768
    Can it not be repaired with araldite glue?
  7. dannyf
    Sep 13, 2015
    2,196
    417
    seems to me glue / tape would be an easier alternative.
    I prefer using a laptop power supply vs. transformers.
  8. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    I tried many glues but nothing worked and as of right now it is missing to many pieces to save the case .. I tried finding a replacement case but none are available and tried modding one but never worked ..
  9. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Do you have any ideas for a case or something ?? My primary iron is my Hakko 888D and this was more just a side project..
  10. tracecom
    Apr 16, 2010
    3,878
    1,396
  11. Dr.killjoy
    Apr 28, 2013
    1,209
    157
  12. tracecom
    Apr 16, 2010
    3,878
    1,396
    I was wondering if you could make one from two by using the best parts from your 939 and the rest from that kit, but maybe not. I may try to follow the article and extract enough info to build something similar.
  13. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Why do you need a new Iron or something?
  14. tracecom
    Apr 16, 2010
    3,878
    1,396
    I have a Hakko 936 that I use quite a lot, so no, I don't really need a new iron. But I have some experience with thermocouples and heat controls and it seems like an interesting project.
  15. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Is it a real hakko or copy ?? I no experience anything like that but I just feel bad that I have a working Hakko 939 with no case ... There was another design that was similar but it was really nice and heat up really quick and not sure the heating time of this design..
    Here is the video that I would love to copy
