Hi All,
This may be a stupid question to most, but I got tired of searching the net so i thought i'd just ask.
Do i have to have a voltage regulator for an electronics project if my supply is a set of batteries whose output matches my required voltage? I'm using a pic16 micro controller and I want to power it with two AAA batteries in series which would give out over 3volts that the pic can use. I guess i'll need to put in some diodes and capacitors to make sure there's no overvoltage spikes or reverse current when i flip on a switch or something, but other than that is there a real reason for me to use one? the pic can operate between 1.8 - 3.6 volts. for the batteries to reach 1.8 volts that would mean that they'd be completely dead anyways before the pic stops working, correct?
also, to get maximum battery life i was thinking of going with a switching regulator instead of linear. is there going to be a huge difference in batt life between the two?
i'm just making things up as i go along with no one here to tell me otherwise . any input/suggestion is appreciated.
thanks
thanks
