Do i need this zener diode?
Discussion in 'General Electronics Chat' started by Paulnoviceb, Jan 23, 2016.
  1. Paulnoviceb
    Jan 23, 2016
    11
    Hi, sorry real novice here. Wondered if I could seek some advice. Just purchased a new 12v capstan motor to fix a cassette deck, an alternative brand of motor as the one I needed is no longer available. I have the task of de-soldering old motor connections and soldering to new motor but old motor has what I'm told is possibly a zener diode (I sent pic to the supplier of old motor). The supplier says not to bother putting this diode on the new motor. Does that sound plausible? There are holes in board that would accommodate it, but not sure what to do. The old motor was the original for this cassette deck, complete with this diode whatever it maybe (although having Googled zener diodes, I'm reasonably happy that it is a zener diode).
  2. MaxHeadRoom
    Jul 18, 2013
    10,844
    2,521
    I doubt a zener in any case you need to know the zener voltage of it.
    Most likely a BEMF diode if it is across the motor.
    Max.
    Dr.killjoy likes this.
  3. Dr.killjoy
    Apr 28, 2013
    1,209
    158
  4. Paulnoviceb
    Jan 23, 2016
    11
  5. Paulnoviceb
    Jan 23, 2016
    11
    This is the component (hopefully I've attached a pic here).
    Moderators note : reduced the picture to its essentials, we do not need the very large white space
  6. MaxHeadRoom
    Jul 18, 2013
    10,844
    2,521
    Is it shot? Can you resuse it?
    Max.
  7. Dodgydave
    Jun 22, 2012
    5,153
    770
  8. Paulnoviceb
    Jan 23, 2016
    11
    Does that sound like something I can disregard with this new motor as advised?
  9. MaxHeadRoom
    Jul 18, 2013
    10,844
    2,521
    Maybe the supplier meant it was not needed as if the motor is switch off when turning, the generated voltage is reverse biasing the diode anyway?
    Max.
  10. Paulnoviceb
    Jan 23, 2016
    11
    He advised not to fit the "zener diode" so I'm a bit dubious of his advice in light of what you guys n gals have certified it as. A Back Emf diode you say, could it be possible I don't need this on an alternative motor to my existing, or is it not a crucial component to the workings in general maybe? Or could it be detrimental if I don't fit for that matter?
  11. MaxHeadRoom
    Jul 18, 2013
    10,844
    2,521
    Motors are pretty rugged devices, although diodes across them are usually meant for the circuit it is being controlled by, what is the technology of the motor? DC brushed or?
    Max.
  12. Paulnoviceb
    Jan 23, 2016
    11
    I'm guessing Yes dC brushed, but I know only little of motors sorry. It's a Mabuchi EG-530AD-2B. It's to replace a Matshushita MMI-6S2LK. It's a 3 head Teac tape deck I've had a long time that looks pristine so I'm trying to get it running again.
  13. Paulnoviceb
    Jan 23, 2016
    11
    Does anybody know if it would hurt to fit this to my new motor? I've included pic of old motor and new
  14. Dodgydave
    Jun 22, 2012
    5,153
    770
    Looks the same size, as long as it spins at the same speed should be ok, try it and see.
    Ahhh nice pics of steam train through Preston...chuff chuff
  15. Paulnoviceb
    Jan 23, 2016
    11
  16. Paulnoviceb
    Jan 23, 2016
    11
    Ha, Yeh wigan reporter comes in handy for something!
  17. Dodgydave
    Jun 22, 2012
    5,153
    770
    If you're from Wigan, your name should be Pie- Eater lol....
  18. Paulnoviceb
    Jan 23, 2016
    11
    Too true!
    Dodgydave likes this.
  19. Paulnoviceb
    Jan 23, 2016
    11
    What do U think about that diode though? Should I transfer it to the new motor?
  20. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    No....
    Mount the motor and give it a try ..
