Do heating elements have high or low resistances?
Discussion in 'Homework Help' started by mahela007, Sep 20, 2008.
  1. mahela007
    Thread Starter Active Member
    Jul 25, 2008
    45
    Does the heating element in something like an electric hot water heater have high resistance or low resistance? I can't seem to find the answer the to that question. If it has low resistance , then why does the filament of a incandescent light bulb have high resistance?
  2. scubasteve_911
    Dec 27, 2007
    1,202
    Heaters and lightbulbs have low resistance.
    For example , a 100W bulb. P = V^2/R
    R = V^2/P
    = 144 Ohms
    1000W heater
    R = 120^2/1000
    = 14.4 Ohms
    Keep in mind that this resistance is 'dynamic'. During startup, there is a much lower resistance seen. This is because as the filament heats, it's resistance increases. Therefore, the current goes down.
    Steve
  3. scubasteve_911
    Dec 27, 2007
    1,202
    I thought about that a bit more, and the answer is relative. Yes, the lightbulb's filament is high resistance in comparison to the wire used to connect it to the AC supply. But, it's certainly not high in comparison to a typical resistor used in an opamp circuit.
    Steve
  4. mahela007
    Jul 25, 2008
    45
    could you pls tell me what an opamp circuit is?
  5. scubasteve_911
    Dec 27, 2007
    1,202
    how about a thank you for answering your original question?
  6. mahela007
    Jul 25, 2008
    45
    hey... I dint mean that to be rude or anything... I really dont know what an opamp circuit is.. thanks anyway
  7. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
  9. DickCappels
    Aug 21, 2008
    2,773
    669
    "Does the heating element in something like an electric hot water heater have high resistance or low resistance?"
    Yes! Next question, please...
    More seriously:
    Hi or low compared to what?
    It will have the resistance required to dissipate the required power. It will be higher than the resistance of a penny but lower than the resistance of a 100 watt light bulb.
