Do any of the devices below offer grounding fault protection
Discussion in 'Homework Help' started by newbieateverything, Sep 2, 2013.
  1. newbieateverything
    Feb 25, 2013
    95
    fuse type isolating switch
    thermal relay
    circuit breaker
    contactor
    thank you. :)
  2. panic mode
    Oct 10, 2011
    1,330
    305
    nope, none have anything to do with grounding...
  3. panic mode
    Oct 10, 2011
    1,330
    305
    GFCI is device that checks for ground leakage current and it is able to cut off power in case of detected leak.
  4. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    I don't want to help you with your homework but if your choices are taken loosely one of them is correct!
  5. studiot
    Nov 9, 2007
    5,005
    515
    I suppose the first thing is to be clear in your own mind as to what is a grounding fault. ie what happens during a grounding fault.
    That should enable you to immediately dismiss two of the options.
    Proper study of the code will allow you to answer the question, do either (or perhaps both) of the remaining two offer protection.
    Tell us what you think - note for the future - this part is a requirement for help on this site.
    Do you know where you might find each of the devices listed?
  6. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    A bit of a catch question, if they are applied in the right circumstance all can except the contactor.
    Max.
  7. panic mode
    Oct 10, 2011
    1,330
    305
    in the right circumstance contactor can be used to drop out circuit power.
    none of the mentioned devices offer ground fault protection but some of them can be used as part of the asked protection.
