DMM probe sharpening?
Discussion in 'General Electronics Chat' started by smilem, May 19, 2015.
  1. smilem
    Thread Starter Senior Member
    Jul 23, 2008
    133
    Hello, I wonder did anyone tried to sharpen their DMM probes, I have Agilent u1168a type of kit probes.
    The tips are not like new, so I though a rubber wheel and dremel is good start, but how thick is the plating? Perhaps they are solid stainless etc?
  2. mcgyvr
    Oct 15, 2009
    4,787
    974
    I'd guess nickel plated brass.. Sharpening will expose the base metal quickly but really shouldn't cause any real problems IMO.. Plating is only maybe 50-100 microns thick max..
  3. smilem
    Jul 23, 2008
    133
  4. nsaspook
    Aug 27, 2009
    3,011
    2,356
    KJ6EAD likes this.
  5. KJ6EAD
    Apr 30, 2011
    1,426
    363
    I also have a set of those. The probes are stainless steel and have very sharp tips which are excellent for SMD PCBs and when extended can reach down between larger components. The same ones are also sold branded for Fluke.
  6. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Another vote for Pomona. They have several styles, some with sopring loaded tips, some firm, some gold plated too I believe.
    I prefer a thin fixed probe myself, though they also make a thicker probe with various tip adaptors such as a clip end (handy for grabbing and holding some wire end).
  7. nsaspook
    Aug 27, 2009
    3,011
    2,356
    KJ6EAD likes this.
  8. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    IME: the plating is usually pretty thin to start with and doesn't last long anyway, sharpening the brass underneath works for a while but ultimately accelerates wear.
    In my first ever job after leaving school, I was fault finding on very early desk calculators that had about 200 DTL chips in them. The boss showed me how to make a sharp pointed probe that doesn't slip off the DIL pin shoulders.
    Take a disposable (non-retractable) ball point pen and take apart the end with the ball in it - at least some of it will be brass, although the whole ball holder that the refill pushes into used to be all brass. Separate the brass bit from the plastic bit it pushes into (you'll need to solder it soon). Get a box of sewing pins (not sewing needles) find something you can use as a die/anvil that you can rest the brass bit in and use a pin to punch the ball out. Now take a new pin that you haven't just blunted and solder it into the brass bit, the lead/wire/cable is soldered to the head end of the pin shaft and its all assembled back to the pen barrel.
    dl324 likes this.
  9. Externet
    Nov 29, 2005
    775
    57
    Very correct, Ian.
    That has been my oscilloscope probe for 10 years. On a red Papermate disposable pen, with RG174. But I used a sewing needle instead of a pin, force fitted. Is much sharper and durable. Protudes about 3mm from where the ball was. And what a pleasant difference to probe without any slipping.!!!
    Made a few for co-workers and enjoyed them. It pierces surfaces so well, ensures firm contact.
  10. dl324
    Mar 30, 2015
    3,377
    651
    Thanks for that tip. I'm going to make some before resuming troubleshooting a power supply. My probe slipped off a lead and shorted a regulator. Fried a couple diodes, blew the fuse, and may have killed the regulator...
  11. DickCappels
    Aug 21, 2008
    2,768
    668
    I sharpen the tips of some DVM probes, but as per mcgyvr sharpening the tips is like smoking. Since the protective coating is soon gone, once you start things get bad if you stop.
