I'm using the TiCC2430 which has an 8051 core and DMA controller. I have set up the ADC to read a series of samples from it's inputs. The samples should be transfered to memory via the DMA controller. When I go to check the values it appears the transfer has not occured. I get an EOC flag for the ADC and an Interrupt from the DMA so I think the conversion and moving of data is working.
I think that I'm looking in the wrong place. I have set the data to be transfered to address 0x0004. When I check XData in IAR Workbench i don't see the correct answer.
Let me know if you want to see my configuration registers.
Thanks.
Thanks.
