dld projects selection
Discussion in 'The Projects Forum' started by wire, Dec 18, 2011.
  1. wire
    Dec 18, 2011
    13
    · 1. 8 Bit ALU, A circuit that takes user inputs, Performs Arithmetic Add Subtract & Logical Comparisons on RISC based system
    · 2.An LED based traffic Signal Generation Circuit of a Road round-about/traffical square. 4 or 5 inputs to a single chowk and do not let signalz create a mesh (use clocks & Timers)
    · 3.A Random Number Generator Circuit That lets a user press a switch/button for some time and gives a random number output on a 7 segment display
    · Make an encryptor or a Counter using a linear feedback shift register(LFSR), a working model
    · SERIAL PORT FPGA based serial port (RS232 standard) ,Designing and coded in Xilinx ISE
    · Make a Converter Circuit that converts between codes ; a binary to decimal converter & others depending on selection signal.
    · Cell phone detector: A circuit set up using disc capacitor/coils but that can detect the RF frequency and raise alarm if a cell phone is being used
    · Digital Clock and its working with model (enable to set it, make it work)
    · Make a Cell phone signal booster; Capture a preset frequency and boost it up as a re-transmitter.
    · A speed Camera Checker Alarm system; Make up a circuit that detects whether any speed monitoring system is working within a certain radius and raise an alarm if it exists.
    · Also following can be made:
    o CACHE SUBSYSTEM
    o TRAFFIC LIGHTS
    o DICE COUNTER
    o NETWORK PACKAGER
    o PROGRAMMABLE PLA
    o QUEUE OF 2-BIT WORDS
    o LINKED LIST OF BITS
    o ROBOT CONTROLLER
    o ALARM CLOCK
    o SERIAL I/O CONTROLLER
    o MEMORY CONTROLLER
    o SPEAKER CONTROLLER
    o MOUSE CONTROLLER
    o SYSTEM TIMER
    o SPEEDOMETER
    if you have information regarding any of these topocs please let me know........can't figure out topoc for final project .....plz its urgent
