Im going to proceed with this experiment tomorrow.
Basically I want to try if a 2200uH RF inductor can be used as xenon tube trigger transformer.
Ive added about 8 windings AWG30 wire on top of the enamel coating.
The charging resistor for the 220nF capacitor is 1 M Ohm.
Ive seen schematics using as little as 22nF.
Only a tiny high voltage charge seems to be required.
As SCR I will use a XL1225.
The tube is a small 26mm kind.
