DIY USB Switch
Discussion in 'The Projects Forum' started by -V-, Jul 22, 2014.
  1. -V-
    Sep 5, 2011
    Hello.. Can anyone please suggest a cirquit or at least where to start.
    I want to make a simple USB Switch cirquit. Basically 4 inputs (PC's) -> 1 Output (Mouse)
    has to be simple and reliable, Input methods need to be changed via momentary push buttons, whitch light up when in use.
    (Do not want to use relay's)
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
    Why build?
    The devices to do what you want area already out there
    Just buy a 4 port USB KVM switch..
  3. -V-
    Sep 5, 2011
    It has to be hidden, only buttons, that are located 2-3m from it, are visible.
    Also all USB cable's have to be with screw terminals.
    The whole thing needs to be easily replaced (without soldering)
