DIY- Sound Volume Equaliser
Discussion in 'General Electronics Chat' started by Zapnologica, Dec 24, 2012.
  1. Zapnologica
    Jun 15, 2012
    41
    Howist,
    I was just thinking of a project that i would like to try and build, depending on how easy it is.
    I want to say make a line of 20 LEDS and the light them up according to the sound input.
    each led would light up according to a voltage or the "loudness of a speaker"
    So almost make a led sound display like often found on DJ mixers?
    I think it is called a VU
    What would my easiest option be?
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    Use an LM3915.
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    Yes, that is the IC normally used.
    Here is one I built for monitoring the sound output of my amplifier's outputs. It uses a peak detector to see the levels better.
