diy pcb at home
Discussion in 'The Projects Forum' started by embpic, May 14, 2014.
  1. embpic
    May 29, 2013
    187
  2. DickCappels
    Aug 21, 2008
    2,758
    667
    With the UV method, you need to use copper clad board with a light sensitive photo resist. Otherwise not much happens.
    There will probably be some suggestions of alternate methods following, so I will mention one. This one doesn't require a coated board and uses an etchant that doesn't leave horrible stains all over:
    http://www.dr-lex.be/hardware/tonertransfer.html
  3. wayneh
    Sep 9, 2010
    12,376
    3,229
    There's a very good thread here somewhere on DIY PCB manufacture. I think Bill Marsden might have tended it, but anyway the folks around here submitted many different approaches to each of the steps. If you're interested and can't find it, let us know. I'm sure we can unearth it.
  4. ErnieM
    Apr 24, 2011
    7,436
    1,625
    You can get custom double sided PCBs with plated thru holes, solder mask, tinned pads a one side silk screen for $34USD for 5x5cm or $44USD for 10x10cm boards. Price includes shipping.
    Good, cheap, not very fast but you can pay more for expedited shipping.
    Just sayin. ;)
    wayneh likes this.
  5. grages
    May 6, 2014
    5
    Wayne is correct, here is the link to the thread
    http://forum.allaboutcircuits.com/showthread.php?t=47681
  6. DC_Kid
    Distinguished Member
    Feb 25, 2008
    641
    9
    i did at-home pcb for making test boards for quite some time. i used a UV light bed to expose circuit tracks printed onto plastic transparencies via laser printer. then expose that to the UV (you need the photo sensitive boards), then you wash away the photo resist and then etch. to etch i used the etching solution from R Shack, my board would have a hole in one corner so i could suspend it in a pool of solution. i used a relatively small plastic cylinder filled with etching solution along with a fish tank heater and small air pump. heat and agitation makes things go faster. after etching rinse with clean water and dry. then i would drill the holes on my drill press using ~029 drill bit. a very slow process, but it works.
