I've been researching this a bit sense i have just purchased a Weller SP40us Soldering iron that apparently from my research seems to have a weakness in the tip area and not surprisingly because on the package it said "Made in Mexico".
So apparently one should stay away from the newer "red" wellers.
My research has brought me to the conclusion that, if you can find them and afford them, Tungsten Copper (Elkonite) electrodes in rod form seem to be the best option when it comes to heat transfer and corrosion resistance.
Mod note: Question was attached to an old thread. Now you have your own.
Welcome to AAC!
Welcome to AAC!
