dividing rectifier voltage
Discussion in 'General Electronics Chat' started by saturatEd, Nov 28, 2008.
  1. saturatEd
    Nov 12, 2008
    6
    Hi there
    If I use a center-tap type full-wave rectifying method (like with diodes) is there any combination of connecting the rectifiers so that their output voltages add up?
    (to use multiple rectifiers of lower voltage rating for a desired voltage output)
    for example, if I had two center tap transformers, each with one rectifier (pair of diodes), and connected the output of first rectifier to the middle tap of the second transformer, and then for total output used center tap of first transformer vs. output of second rectifier, would that work?
  2. leftyretro
    Nov 25, 2008
    394
    No I don't think that would work at all, but you would have to draw it out to say for absolute sure. However if you already have two transformers you can wire their secondary windings in series (and their primary winding in parallel) and use one bridge diode rectifier and obtain double the voltage.
    Make sense?
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You mean, using the output of one transformer/rectifier as the "ground" reference for the next transformer/rectifier?
    Yes, you could do that; but if the outputs had different current ratings it might be rather inefficient. You'd also incur double the loss via the Vf of the rectifier diodes.
    Usually, the CT is used as the ground reference, and the rectifiers are connected by the anodes to the ends of the winding; both cathodes are connected together.
    Alternatively, a fullwave bridge rectifier could be used on just the ends of the windings, ignoring the center tap.
  4. saturatEd
    Nov 12, 2008
    6
    Yes that's what I meant, using the output of one rectifier (it's both cathodes connected to the center tap of the second transformer) as a ground for the second transformer/rectifier.
    Assuming that the current rating is the same for both of them and that the total output does not load this pair of rectifiers above that current rating
    thanks for the answer
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    That's not the way it's normally done, but I suppose you could do it that way.
    Usually, one would simply wire the secondaries in phase, in series, and either use rectifiers at either end and tie the "new" center tap to ground, or just use a fullwave bridge rectifier across the whole thing.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Don't forget voltage doublers (triplers, quads...).
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Voltage doublers/triplers work fairly well, but each time the voltage is not-quite-doubled, the available current drops by more than half. Diodes are cheap, but they're not ideal. The more current you try to get through them, the higher their Vf, thus the voltage loss.
