dividing frequency from d flipflop
Discussion in 'The Projects Forum' started by brandonb, Nov 27, 2010.
Thread Status:
Not open for further replies.
  1. brandonb
    Nov 14, 2010
    9
    how you guys doing(first post) i have a hcf4013be d-flipflop that i bought 15 from digikey- im trying to make a frequency divider out of it, when i hook it up like i've seen on the web to do the above it only gives me battery voltage, is my frequency too low at 5-50hz or am i not using the correct dflop....if i read the datasheet correctly it says that its possible- so tell me what you think? HOOK UP-dc 12v 25% duty frequency signal input to clock pin- d jumped to qnot- clear and reset not connected- q output always batt voltage for somereason....12v supply hooked up to chip,
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    They're static so they work from DC to whatever their rated speed is.
    Post the schematic you used.
    brandonb likes this.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Not only the schematic, but the kind of logic you are using. Only 4000 series CMOS will take +12 VDC without blowing up.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    Datasheet for HCF4013
    Static Dual D FF
    It is rated for up to 15V Max speed of 16Mhz. For a multi stage frequency divider, I'd suggest a CD4040 or similar, I made a thread on that just a few days ago (kid project).
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Which I'm currently helping on, between peeks at the board.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This turned out to be a circuit to affect fuel injection in an automotive engine.
Thread Status:
