Divide in C code for PIC
Discussion in 'Programmer's Corner' started by FroceMaster, Sep 21, 2014.
  1. FroceMaster
    Jan 28, 2012
    402
    Hi
    Need to do this.
    1/25000*125000*60
    if i do like this,
    Code (Text):
    1. timer = (TMR1H << 8)| TMR1L;
    2.
    3.   tid_rpm= timer *(timer_tick+1);
    4.
    5. nyrpm =1/tid_rpm*125000*60;
    Any hint on doing this ?
    have define all as float.
  2. shteii01
    Feb 19, 2010
    3,519
    515
  3. ErnieM
    Apr 24, 2011
    7,447
    1,628
    Any hint on doing what?
    If you expect any help you need to state what you are trying to accomplish.
    Unless 1/187,500,000,000 = 5.3333333333333333333333333333333e-12 is the answer you need.
  4. kubeek
    Sep 20, 2005
    4,691
    806
    And i thought the answer was 300.
    The correct order of operations would be 125000*60/25000 in order to prevent loss of precision.
  5. Brian Griffin
    Member
    May 17, 2013
    40
    12
    Which PIC is it you want to do a divide function inside? A PIC16F doesn't have hardware multipliers, only PIC18F and PIC24F have them.
  6. FroceMaster
    Jan 28, 2012
    402
    Yes that way works. ☺
    16f690 is the Pic.
