I am trying to make a distance detector using IR emitter/detector. I want this application to work outdoors so I have implemented a 555 timer in the emitter circuit to create a frequency of about 4kHz. I then created the detector circuit with the photodetector and put the output into a high pass filter using an op amp with a frequency of 3kHz.
For some reason, the detector circuit does not seem to work with the photodetector. If i hook the output of the 555 into the input of the high pass filter then the output goes high, showing the circuit works and detects the frequency. If I connect +5V to the input of the high pass filter, the output is 0V, showing the filter works again. If I test the photodetector using a resistor and power supply, it detects the IR from the emitter, so I know both emitter and detector work fine. It only does not work when I have the detector in series with the high pass filter circuit to detect the correct frequency.
I simply hooked the collector of the photodetector to +5V and the emitter pin of the photodetector to the input of the high pass filter.
Does anyone have any good troubleshooting steps I can take?
The Emitter GIF attached is how my 555 is hooked up. I have a IR emitter and 470 ohm resistor in series off the output. The JPG attached is my detector circuit.
