dissipation factor and heat radiation factor
Janani_Rajkiran
Joined Nov 1, 2016
46
Do Both mean the same or are they different for aluminium electrolytic capacitors or Tantalum Capacitors
How can I calculate the heat radiation factor for both?
How can i calculate the temperature rise at the surface of the capacitor? is there a formula to do this?
Picbuster
Joined Dec 2, 2013
1,047
I do not understand your question however;
A capacitor has an impedance when an ac current flows then you may use the p= z*i^2 z is depending on Freq and the way these things are build.
Now heat introduced by P is de depending on thermal resistance and volume of its surface.
its possible but useless look at the datasheets.
But if you want to calculate.
Happy calculating.
Picbuster
34,470
The dissipation factor is a measure of the capacitor internal parasitic resistance.
It has nothing to do with heat radiation from the device.
