Hi, my project is about displaying the pressure range on a 16x4 LCD for four pressure sensors input. I'm new to this, but I have try writing out codes by referring to other online sources, doesn't know whether the coding works, hope somebody can help up.
#include<LiquidCrystal.h>
Liquid Crystal lcd(12, 11, 5, 4, 3, 2);//set pins for LCD
int FSR1 = A0;//fsr1 connected to analog pin 0
int FSR2 = A1;//fsr2 connected to analog pin 1
int FSR3 = A2;//fsr3 connected to analog pin 2
int FSR4 = A3;//fsr4 connected to analog pin 3
//variables for level of force applied to FSRs
int FSR1level = 0;
int FSR2level = 0;
int FSR3level = 0;
int FSR4level = 0;
void setup()
lcd.begin(16, 4);//set up LCD no.of columns & rod
lcd.setCursor(0, 0);
lcd.print("1st:");// set up 1st column for FSR1level
lcd.setCursor(0, 1);
lcd.print("2nd:");// set up 2nd column for FSR2level
lcd.setCursor(0, 2);
lcd.print("3rd:");//set up 3rd column for FSR3level
lcd.setCursor(0, 3);
lcd.print("4th:")//set up 4th column for FSR4level
void loop()
//divide by four as analog read is 4x sensitive as digital
FSR1level = analogRead(FSR1) / 4;
FSR2level = analogRead(FSR2) / 4;
FSR3level = analogRead(FSR3) / 4;
FSR4level = analogRead(FSR4) / 4;
// Threshold preset for FSR1level
if (FSR1level < 200)
lcd.setCursor(5, 0);
lcd.print("Very Weak");
else if (FSR1level < 500)
lcd.print("Weak");
else if (FSR1level < 800)
lcd.print("Moderate");
else {
lcd.print("Strong");
delay(5000);
// Threshold set for FSR2level
if (FSR2level < 200)
lcd.setCursor(5, 1);
else if (FSR2level < 500)
lcd.print("Weak");
else if (FSR2level < 800)
else {
delay(5000);
// Threshold set for FSR3level
if (FSR3level < 200)
lcd.setCursor(5, 3);
else if (FSR3level < 500)
lcd.print("Weak");
else if (FSR3level < 800)
else {
delay(5000);
// Threshold set for FSR4level
if (FSR4level < 200)
lcd.setCursor(5, 4);
else if (FSR4level < 500)
lcd.print("Weak");
else if (FSR4level < 800)
else {
int FSR1level = 0;
int FSR2level = 0;
int FSR3level = 0;
int FSR4level = 0;
void setup()
void loop()
lcd.print("Weak");
else {
delay(5000);
lcd.print("Weak");
else {
delay(5000);
lcd.print("Weak");
else {
delay(5000);
lcd.print("Weak");
else {
