Displaying on 2*16 LCD floating numbers
Discussion in 'Programmer's Corner' started by AustinCann, Mar 11, 2011.
  1. AustinCann
    Jan 30, 2011
    12
    Dear all
    I am finding transformer turn ratio using pic 16f877a and 2*16 LCD. I acquired the signal for primary voltage upto 3 decimal places as well as signal for secondary upto 3 decimal places.
    The problem comes when I divide the numbers and display on the LCD. The best I achieved is the ratio result to the nearest integer which is unfortunately no good. Please find below my code. Cant find the way out really. Any ideas?
    Kind Regards
    unsigned char ch,ch2,ch3;
    unsigned int adc_rd1,adc_rd2;
    char *text;
    long tlong,tlong1,tlong2,tlong3,tlong4,rate;
    void main() {
    TRISA = 0xFF; // designate PORTA as input
    TRISB = 0X00;
    //INTCON = 0; // disable all interrupts
    Lcd_Config(&PORTB, 4, 5, 6, 3, 2, 1, 0); // Lcd_Init_EP5, see Autocomplete
    LCD_Cmd(LCD_CURSOR_OFF); // send command to LCD (cursor off)
    LCD_Cmd(LCD_CLEAR); // send command to LCD (clear LCD)
    text = "TTR Finder"; // assign text to string
    LCD_Out(1,1,text); // print string a on LCD, 1st row, 1st column
    text = "Initializing...."; // assign text to string
    LCD_Out(2,1,text); // print string a on LCD, 2nd row, 1st column
    delay_ms(3000);
    text = "Reading TTR";
    LCD_Out(1,1,text);
    text = "Please wait!" ;
    LCD_Out(2,1,text);
    delay_ms(2000);
    LCD_Cmd(LCD_CLEAR);
    while (1) {
    text = "Vs:"; // assign text to string
    LCD_Out(1,1,text); // print string a on LCD, 2nd row, 1st column
    ADCON1 = 0x83; // configure VDD as Vref, and analog channels
    adc_rd1 = ADC_Read(2); // get ADC value from 2nd channel
    tlong = (long)adc_rd1 * 5000; // covert adc reading to milivolts
    tlong1 = tlong / 1023; // 0..1023 -> 0-5000mV
    ch = tlong1 / 1000; // extract volts digit
    LCD_Chr(1,4,48+ch); // write ASCII digit at 1st row, 4th column
    LCD_Chr_CP('.');
    ch = (tlong1 / 100) % 10; // extract 0.1 volts digit
    LCD_Chr_CP(48+ch); // write ASCII digit at cursor point
    ch = (tlong1 / 10) % 10; // extract 0.01 volts digit
    ch = tlong1 % 10; // extract 0.001 volts digit
    LCD_Chr_CP('V');
    Delay_ms(1);
    text = "Vp:"; // assign text to string
    adc_rd2 = ADC_Read(3); // get ADC value from 2nd channel
    tlong2 = (long)adc_rd2 * 5000; // covert adc reading to milivolts
    tlong3 = tlong2 / 1023; // 0..1023 -> 0-5000mV
    ch2 = tlong3 / 1000; // extract volts digit
    LCD_Chr(2,4,48+ch2); // write ASCII digit at 2nd row, 9th column
    LCD_Chr_CP('.');
    ch2 = (tlong3 / 100) % 10; // extract 0.1 volts digit
    LCD_Chr_CP(48+ch2); // write ASCII digit at cursor point
    ch2 = (tlong3 / 10) % 10; // extract 0.01 volts digit
    ch2 = tlong3 % 10; // extract 0.001 volts digit
    LCD_Chr_CP('V');
    Delay_ms(3000);
    LCD_Cmd(LCD_CLEAR);
    delay_ms(100);
    text="TTR=";
    LCD_out(1,1,text);
    delay_ms(100);
    rate=(long)(tlong3/tlong1)*1000;
    ch3 = rate/1000; // extract volts digit
    LCD_Chr(1,6,48+ch3); // write ASCII digit at 2nd row, 4th column
    LCD_Chr_CP('.');
    ch3 = (rate / 100) % 10; // extract 0.1 volts digit
    LCD_Chr_CP(48+ch3); // write ASCII digit at cursor point
    ch3 = (rate / 10) % 10; // extract 0.01 volts digit
    ch3 = rate % 10; // extract 0.001 volts digit
    Delay_ms(5000);
    LCD_Cmd(LCD_CLEAR);
    delay_ms(100);
