Display off-frequency with just LEDs ?
Discussion in 'The Projects Forum' started by Externet, Jan 28, 2015.
  1. Externet
    Thread Starter AAC Fanatic!
    Nov 29, 2005
    780
    58
    Hi all.
    How would you make the simplest possible analog sensing circuit that will turn a LED on if an inputted frequency is above 1KHz and another LED if the frequency is below 1KHz ?
    Does not matter if at 1 KHz both leds are on or off.
  2. #12
    Nov 30, 2010
    16,704
    7,354
    After about 2 minutes of thinking, a pair of filters starts with the question, "How sharp do you want it?"
    If you do a F to V converter and add a comparator at the DC level that represents 1KHz, that eliminates most of the filtering.
    Use a window comparator and, "How sharp do you want it?" becomes, "dial a Q".
    GopherT likes this.
  3. Externet
    Nov 29, 2005
    780
    58
    Thanks, #12.
    The 1KHz frequency can be off about +/- 20 Hz before indicators take action.
    Do you know of any PLL IC that some pin will go negative or positive if deviated from the frequency ?
  4. #12
    Nov 30, 2010
    16,704
    7,354
    Ummm...no. Did you know there are F to V chips, and they are different from PLL's?
    I never built one of these, I'm just thinking of how a guitar tuner works.
    Yes, PLL chips go positive or negative when the input is not the center frequency. I just don't know the part number.
  5. ronv
    Nov 12, 2008
    3,403
    1,477
    Sine wave or square wave?
  6. MrChips
    Oct 2, 2009
    12,636
    3,455
  7. Externet
    Nov 29, 2005
    780
    58
    Sine wave.
  8. GopherT
    Nov 23, 2012
    6,319
    4,043
    Use a comparitor on a Microcontroller, any signal that is more than 1000 microsecons between rising edges is less than 1000 Hz, anything faster is more. Adjust output to pin with appropriate LED.
  9. Reloadron
    Jan 15, 2015
    1,055
    275
    There are a number of ways but my first thought
    That would be how I would do it. Not many parts and a few LEDs can be hung on the output. That or a GopherT suggest a micro controller.
    Ron
