display 4 digits using two 7 segment displays
Discussion in 'Homework Help' started by Mario Emad, Feb 17, 2009.
  1. Mario Emad
    Feb 17, 2009
    Assuming that it's Common Anode, and I want to display a 4-bit no.(with switches) on two 7-segment displays , how?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You are urged to always start a new thread with each question. Placing your topic in an existing thread can be confusing.
    This is the old thread - http://forum.allaboutcircuits.com/showthread.php?t=15473.
    As in things electronic, there are always more than one way to get there. The hard way would be to use 14 SPDT switches and switch betenn two pairs of drivers. Another way is to use multiple pole rotart switches and shift the source of the data to one pair of decoders.
    We have no idea of the arrangement of elements in your circuit, so a sensible answer becomes difficult. What is the circuit? Is it multiplexed? Is there a reason why adding two more displays is not possible?
