disobedient NPN BJT
Discussion in 'General Electronics Chat' started by WolfgangBS, May 1, 2013.
  1. WolfgangBS
    May 1, 2013
    Hey everyone, I have run into a very strange problem, and I am hoping you can enlighten me. I have tried to test the attached circuit. However when I do the BJT conducts even when the base is grounded. The blue values are measured. I am using the BJT as a switch and I know I have already pushed my BJT way past the max power. All other components are high power rated. But as the circuit is, it should not even be conducting, because Vce max is 40V. When I designed this high current circuit, I assumed 6.3V would drop on the diode, collector to emitter saturation voltage would be about a volt, and the rest would drop across the resistor. However it seems that about a volt is being dropped across the resistor and the rest across CE. Is this because my resistance is so small? How can I remedy this? I was thinking of just using a higher power rated BJT but I don't know if that will stop it from conducting when it is not supposed to. I don't really want to change my resistor or diode because I want high current. Thanks for the help.
  2. #12
    Nov 30, 2010
    16,705
    7,355
    Yes, this circuit should be off, therefore you have a bad component or a mistake in connecting things. However, why would you expect 6.3 volts across a forward biased diode?
    "A volt" is being dropped across the resistor...20 ohms...that's .05 amps, not .25 amps.
    Keep talking.
    ps, "high current" is relative. In the last few days, several people have come here asking about 30 or 40 amps.
  3. GopherT
    Nov 23, 2012
    6,326
    4,054
    Your Zener needs to be reverse biased (cathode to + rail). When forward biased as you show, the voltage drop will be like a normal diode of 0.6 volts.
  4. #12
    Nov 30, 2010
    16,705
    7,355
    Fooled one of us. That's not a zener symbol. Still, it's forward biased, and that is less than a volt, zener or not.
  5. WolfgangBS
    May 1, 2013
    Lets just say the voltages I mentioned earlier are true and the current is unknown. The design is on perf board and I cannot easily remove components. There are no shorts anywhere. Lets also say that the pictured diode is a "normal" diode with an unusually large forward bias potential.
  6. TheComet
    Member
    Mar 11, 2013
    88
    12
    If the Bjt is conducting, you can calculate Ic with this:
    Ic = (Vcc-Vce-Vd)/R1 = (12V-1V-6.3V)/20 = 235mA.
    I still don't understand why the diode would be dropping 6.3V. Is it a Zener? Something else?
    I assume your Bjt is broken, or you connected it incorrectly if it is conducting when it shouldn't.
    TheComet
  7. ErnieM
    Apr 24, 2011
    7,442
    1,628
    A diode cannot have 6.3 volts across it when forward biased. Cannot.
    So it is not a diode. You may have bought a diode but it is no longer such. It is broken.
    Unless... how long since you checked the batteries in your digital meter? My meter reads low when the batteries are nearly dead but yours may work differently.
    Also TheComet makes good points about the transistor. It too is broken.
  8. studiot
    Nov 9, 2007
    5,005
    515
    Wolfgang,
    It is the easiest thing in the world to miswire a circuit, we have all done it.
    I recommend that you check carefully that the transistor is actually connected as shown and not reversed.
    Then repost the circuit with accurate measurements and all component types, including the 'diode' and list which end is marked as cathode on your diode.
    I say accurate measurements because the reported voltage drops add up to
    greater than the 12 volts supply. Your current calculations have already been questioned.
  9. kubeek
    Sep 20, 2005
    4,691
    806
    Pull enough current throug it and it will. Only problem is that the current needs to be in tens of amps and the diode will melt very shortly after.
  10. atferrari
    Jan 6, 2004
    2,672
    785
    Are you maybe talking of 0.63 V instead?
  11. WolfgangBS
    May 1, 2013
    I made it work with 2.8W BJTs
  12. ramancini8
    Member
    Jul 18, 2012
    447
    119
    There is no path for the collector leakage current (Icbo), so it flows through the base-emitter causing the transistor to partially turn on.
  13. Ron H
    Apr 14, 2005
    7,050
    657
    The base-to-ground resistor is present, and it's only 680 ohms.
    I think he has the collector and emitter swapped, as studiot suggested. If so, the EB junction will break down at around 6V, leaving Vec≈Veb+0.7V, where 0.7V is the now-forward-biased BC junction. Approximately 1mA will flow through the 680Ω resistor.
  14. JoeJester
    Apr 26, 2005
    3,403
    1,227
    What gets me is ...
    5V + 6.3 V only leaves 0.7 volts across the 20 ohm resistor or 0.035 A of current, considerably less than the 0.25 posted.
    Now ... using the 0.25A posted, you'd have IR of 5V + Vce 5V leaving 2V acrossed a forward biased diode. Now, I've seen diodes drop almost 2V when 10 amps was put through them, but that would change the dynamics of the whole circuit as well.
    Things just aren't adding up. The OP left off the Vbe voltage.
    Why doesn't the OP post the component values, like their 6.3V diode?
