can someone help me to know how to find particular solution and homogenous solution for discrete time signal ,if you know links for that subject ,i did search on google but i can not find something
thanks
thanks
Are you referring to difference equations, which are analogous to differential equations for continuous-time signals?
Tons of stuff if you know how to use Google.
Is there a particular example that you could work through and post on here? That might be more useful.
JP
Okay, are you given any initial conditions of y[n] for n < 0? If not, assume y[-2] = 0 and y[-1] = 0 then go through each value of y[n] for n.like y[n]=y[n-1]+y[n-2]+x[n]
where x[n]=n^2*u[n]
u[n] is unit step function
y[0] = y[-1] + y[-2] + x[0] = 0 + 0 + 0^2*u[0] = 0 + 0 + 0*1 = 0
y[1] = ...
Do this until the values converge and stop changing.
In the example that you have given, if there are no initial conditions your function will be a zero function for all n.
