Discrete-Time Functions
Discussion in 'Math' started by RdAdr, Oct 6, 2015.
  1. RdAdr
    May 19, 2013
    214
    I attached a picture with my confusion.
    Hopefully, someone will be able to shed some light upon this.
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    When you claim
    f(u[n] - u[n-4]) = f(u[n]) - f(u[n-4])
    you are claiming that f() is a linear function.
    Is it?
    Why are you saying that
    f(u[n-4]) = (n-4)u[n-4]
    You have
    f(x[n]) = n * x[n]
    Whatever you plug in as the argument of f(), that only replaces the parameter x[n] in the expression.
  3. Lool
    Member
    May 8, 2013
    117
    12
    Just a quick comment that the step f(u[n-4])=(n-1) u[n-4] is the incorrect step as mentioned above.
    The step f(u[n] - u[n-4]) = f(u[n]) - f(u[n-4]) is correct because this is a linear time varying system.
  4. RdAdr
    May 19, 2013
    214
    I figured it out. I was confused between the actual model and the input-output relationship that arises from it.
    Thanks for the answers.
