Discrete Pulse Width Modulator
Discussion in 'The Projects Forum' started by iimagine, Nov 28, 2013.
  1. iimagine
    Thread Starter Active Member
    Dec 20, 2010
    129
    9
    Adding a couple more transistors to my discrete linear generator, we have a discrete PWM [​IMG]
    What can I say? I like discrete stuffs :D
    absf and scelesticsiva like this.
  2. scelesticsiva
    Nov 29, 2013
    25
    Can u brief on the circuit?
  3. iimagine
    Dec 20, 2010
    129
    9
    Sure, although I have developed a more efficient circuit, If you are interested I will post it.
    Here is how it works: Q1-Q4 are used to generate a linear ramp; Q5+Q6 forms an emitter buffer stage; Q7 + Q5 forms a longtail pair and is used as a comparator; Q8 + Q9 is the output stage
    scelesticsiva likes this.
  4. wayneh
    Sep 9, 2010
    12,368
    3,224
    Where do you actually modulate the pulse width? I see no variable components.
  5. scelesticsiva
    Nov 29, 2013
    25
    He he he!"""SALUTE & BRAVO""" Thanks btw iimagine:)
  6. iimagine
    Dec 20, 2010
    129
    9
    R7/R8 divider. I was too lazy to simulate a variable resistor :D
  7. wayneh
    Sep 9, 2010
    12,368
    3,224
    It might be nice to show how well it works, i.e. show what range of percent you can obtain. For instance is it 5-95% or full 0-100%. The frequency of operation is also a critical parameter folks need to know.
    If you actually build one and play with it, you should submit it to the completed projects section.
  8. iimagine
    Dec 20, 2010
    129
    9
    Here is the updated version with graphs and some info
    I'm planning to build this soon as I have the time and will post it
    Edit: I know for a fact that my linear ramp gen does work, I have built and tested it. So its just a matter of 'tweaking' the comparator
    absf likes this.
  9. iimagine
    Dec 20, 2010
    129
    9
    Well, here are the test results from the latest version breadboarded. Not too clean, needs a little 'tweaking' but worked on the first try! :)
    I used 2n4401/2n4403 for all transistors; R7/R8 voltage divider was replaced with a 500k pot
    Next, I will build a Color Organ using this circuit to drive LEDs :D
    Please, as always, I would really appreciate any comments on what you think of it and any suggestions to further improve it.
    PS: Since it was breadboarded, the freq was not too stable.
  10. ronv
    Nov 12, 2008
    3,392
    1,449
    Maybe a little hysteresis would stabilize the comparator?
    iimagine likes this.
  11. iimagine
    Dec 20, 2010
    129
    9
    Thanks for the suggestion, a little hysteresis would definitely makes it better.
  12. RichardO
    May 4, 2013
    1,334
    429
    Just because it is on a breadboard (a solderless one, I suppose) does not make it unstable. I have built many function generator circuits with sine, square and triangle waveforms. Some work as high as 20 MHz and they are stable and predictable.
    Can you post a picture of how your prototype looks looks?
  13. RichardO
    May 4, 2013
    1,334
    429
    Good advice. I should have looked at your waveforms before posting the previous comments.
    I would still be interested in pictures of your prototype, though. :)
  14. iimagine
    Dec 20, 2010
    129
    9
    I have pics of my prototypes; breadboard and protoboard :)
    How do I upload these pics? they are too large! approx 2meg per pic.
    I was in the middle of constructing it on the protoboard when I got a suggestion from ronv, It was too late to make any changes so I went ahead and completed it, I will post read outs from this protoboard tomorrow, right now it is working good as an LED dimmer :)
