Disconnect dead battery from circuit
Discussion in 'The Projects Forum' started by bignick270, Oct 13, 2009.
  1. bignick270
    Thread Starter Active Member
    Mar 25, 2009
    36
    How can I disconnect a dead rechargeable battery from a circuit to prevent leakage current from completely draining the battery therefore damaging it? It would be great to find a solution that would have a minimum increase in operating current and a minimum voltage drop from the battery supply.
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    What sort of battery?
  3. bignick270
    Mar 25, 2009
    36
    2 2500 mAh NiMH AA batteries in series
  4. t06afre
    May 11, 2009
    5,939
    1,222
    how much current do your circuit draw?
  5. bignick270
    Mar 25, 2009
    36
    no more than 150 mA.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, two AA batteries put out too little voltage to control a MOSFET gate.
    BJT's and relays would require too much current.
    Probably best to just use a simple switch to disconnect the batteries.
  7. bignick270
    Mar 25, 2009
    36
    The device is enclosed in a case and it can not be easily opened for controling a switch and it is not pratical to have a switch on the outside of the case.
  8. t06afre
    May 11, 2009
    5,939
    1,222
    I may be wrong here. But the some N fet from International rectifier seams to have a very precise Gate Threshold Voltage fixed at 0.7 volt. As some examples IRF7401, IRF7402,IRL3103,IRL3402,IRL3502. Maybe you can use one battery to control the V gate/source voltage
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK, so cut a small piece from a plastic milk jug, and insert it between the terminals of the two batteries. That will prevent any current flow from occurring.
  10. Bernard
    Aug 7, 2008
    4,240
    414
    Or use a mercury switch, turn box over & batteries are off; used sucessfully in well logging probe 1957.
