Discharging a Super capacitor
Discussion in 'The Projects Forum' started by Macky Buenaflor, Feb 25, 2016.
  1. Macky Buenaflor
    Feb 25, 2016
    6
    How do you discharge a super capacitor without the use of any discharging circuit? What load can I use for it to be discharged to near single digit volts in minutes? Can I use an LED light here and if so, how long would it take to discharge it if I'm using a 3-5W LED light bulb? Thank you! :)
  2. Alec_t
    Sep 17, 2013
    5,971
    1,135
    What voltage is the cap charged to?
    What is the capacitance?
    What is the rated Vf of the LED?
  3. HitEmTrue
    Member
    Jan 25, 2016
    32
    9
    Under what circumstances to do you want it to discharge? If it lights the LED, there will be a circuit. :)
  4. tcmtech
    Nov 4, 2013
    2,113
    1,751
    I prefer to use super resistors to discharge my super capacitors. ;)
  5. Macky Buenaflor
    Feb 25, 2016
    6
    Sorry i forgot to put in the details
    48V, 165F supercapacitor. :)
    Any other way to discharge it that you would recommend (besides having a discharge circuit)? Thank you! :)
  6. wayneh
    Sep 9, 2010
    12,382
    3,241
    No circuit, no discharge. Except for a slight leakage.
    How quickly do you want this to happen?
  7. Alec_t
    Sep 17, 2013
    5,971
    1,135
    :confused: Anything conductive connected across the cap would constitute a discharge circuit.
  8. tom_s
    Member
    Jun 27, 2014
    287
    342
    i was going to suggest a decent flat blade screwdriver
    but i won't :)
  9. Alec_t
    Sep 17, 2013
    5,971
    1,135
    A 220V 3kW fire would make a relatively safe load to discharge the cap.
    Here's the discharge curve over a 100 minute period
  10. kubeek
    Sep 20, 2005
    4,689
    806
    The capacitor when fully charged stores roughly 190kJ, so if you were to draw 5W from it it would take 38000 seconds to discharge, that is 10.5 hours.
