Discharging a Li-ion camcorder Battery
Discussion in 'The Projects Forum' started by Matthew Phillips, Dec 22, 2013.
  1. Matthew Phillips
    Dec 22, 2013
    Hi guys, this is going to sound stupid but i have a 7.2v camera battery i would like to discharge before i dispose of it, now i don't have much in the way of equipment but i have a Analogue multimeter for testing the voltage. i have got these to discharge it: a 12v fan and a 12v car radio attached to it but it wont discharge even a little. Its been on for at least 30 minutes. Can someone recommend a faster discharge method. (THE METHODS MUST BE SAFE)
  2. Alec_t
    Sep 17, 2013
    5,976
    1,136
    Car headlight bulb? Electric kettle?
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    If it is a battery pack, there is control electronics inside to prevent you from discharging it too far because Li batteries can catch fire from that. The electronics open a FET switch when the battery voltage drops to a pre set point. You should never try to discharge an Li battery to zero.
  4. GopherT
    Nov 23, 2012
    6,315
    4,037
    The other option is to recycle it - Staples stores have recycle boxes if you are in the US.
  5. trader007
    Feb 27, 2010
    222
    19
    not all battery packs have chips in them though..
    I would just recycle the battery pack. Well I mean I would put it on a grill and shoot it with a nailgun to watch the fireworks... but that's not safe.
