Disc capacitor //Electrolytic polarised capacitor
Discussion in 'Analog & Mixed-Signal Design' started by sohamkul, Aug 2, 2016.
  1. sohamkul
    Jun 24, 2016
    43
    Hello Everyone ,
    Few days back i had posted a question related to an instrumentation amplifier ,
    As per suggestions and advice from forum members..i made the circuit...and it works like charm !!!
    Now i had ordered 0.47microfarad disc type capacitors and i got 100 electrolytic polarised capacitors ...supplier wont take it back ..:(
    Please review and suggest if i can use 0.47 electrolytic polarised capacitors.
    Images :
    1) circuit (capacitors C3 and C4)
    2)type of capacitors i expected
    3)the ones that i got ...
  2. wayneh
    Sep 9, 2010
    12,382
    3,238
    Since one end of C3 is grounded, a polarized cap will be OK if circuit voltages never drop below ground. I didn't take the time to study your circuit to verify that is true. The situation at C4 is even less clear to me. But if the cap is always charged with one polarity, the polarized cap will be OK.
    The supplier is acting very badly, if in fact you can prove what you ordered. Most suppliers I've dealt with would let you keep the wrong part and ship the proper ones to you. Otherwise, you'll never go back to them.
    Sinus23 and sohamkul like this.
  3. AlbertHall
    Jun 4, 2014
    2,262
    448
    If the op-amps are supplied with positive and negative supply rails with the circuit ground being half-way in between then, no, you can't use electrolytics in those positions as the input and output of that last amplifier may be either positive or negative depending on the input.
    sohamkul likes this.
  4. crutschow
    Mar 14, 2008
    13,493
    3,372
    It's problematic to use those electrolytics in those two spots.
    Afraid you will need to buy some non-polarized caps for that.
  5. hp1729
    Nov 23, 2015
    2,097
    232
    Help us avoid dealing with that supplier in the future. Who from? What part number did you order?
  6. GopherT
    Nov 23, 2012
    6,308
    4,029
    Use four of the caps you have, connected as follows to make one non-polar cap assembly of .47uF. Be sure to connect + to + on the caps.
  7. KeepItSimpleStupid
    Mar 4, 2014
    1,271
    224
    (Below is incorrect as suggested)
    474 = 47 with 4 zeros pF or 47 000 e-12, or 47 nf (e-9) or 0.047 uF (e-6) not 0.47 uf
    0.47 uF is a little high for a ceramic cap. Polyester caps are non-polarized and have better tolerances.
    Edit:
    Thanks Guys. (Migraine): Corrected version.
    474 = 47 with 4 zeros pF or 470 000 e-12, or 470 nf (e-9) or 0.47 uF (e-6) or 0.47 uf
  8. hp1729
    Nov 23, 2015
    2,097
    232
    Well 47 and 4 zeros is 0.47 uF alright (470 000 pF). Not unusual for a ceramic cap.
    KeepItSimpleStupid likes this.
  9. GopherT
    Nov 23, 2012
    6,308
    4,029
    Wrong.
    A cap labeled 474 = 0.47uF (470 nF).
    470000 pF
  10. OBW0549
    Mar 2, 2015
    1,392
    936
    There is an error in the schematic in post #1: the inputs of U3 are reversed. As drawn, the circuit will not operate; rather, the positive feedback through R10 will force U3 to latch up, with its output stuck at either the positive or negative supply rail.
    GopherT likes this.
  11. GopherT
    Nov 23, 2012
    6,308
    4,029
    OBW0549 likes this.
