Disable the 'timing' of one side of a 556 circuit
Discussion in 'The Projects Forum' started by cpqfe29, Jul 4, 2010.
  1. cpqfe29
    Jan 30, 2010
    26
    I have a Wii wireless extended sensor bar (I like it better that the standard one) that I modified to accept an external regulated voltage source when I need it at home. I left it the ability to run off of batteries when I travel. This works great.
    The only issue I have is that it has a 556 timer that lets you select one or two hours of use before it shuts down. Remember this was a battery only device. I would like to keep one timer (either the 1hr or the 2hr) useable for when I am on batteries and I would like to disable one to supply endless power when it is plugged in.
    You can select 1 or 2 hr by a push button.
    How can I disable one of these circuits on this timer?
    BTW: I assume it is a 556 timer. There is a chip with 17 legs and of course two settings (one and two hour) and a few capacitors I assume that control the timing. There are no markings.
    Edit: It is 14 pins - Typo.
  2. Ron H
    Apr 14, 2005
    7,050
    657
    A 556 has only 14 pins. I don't know of a chip with an odd number of pins. Yours is probably either a microcontroller (e.g. PIC), and you miscounted, or it is a custom chip.
  3. retched
    Dec 5, 2009
    5,201
    313
    17 legs? Your on your own with that, friend.
    Are you sure its a 556?
    It may be a 556+ using a base 556 and made into a house part of an OEM specific manufacture.
    But 17 pins?
    Take a picture of that and post it, would ya?
    That reminds me of a bad joke..
    What goes 99-THUMP 99-THUMP?
    A centipede with a wooden leg! ;)
    Thank you, thank you! Ill be here all week.
  4. cpqfe29
    Jan 30, 2010
    26
    My mistake it is 14 pins.
