I am working on a project and I am very very new to antenna theory, im used to Op-amps(Diff, filters, etc....) but this is new to me. I need to pick up a electric field 1mV/cm that can be produced up to 2 meters underwater. So 12.5mV at the source and 1mV, 2 meters away(if I converted it correctly, since it's a dipole the electric field created by the source doesn't propagate, inverse of the distance cubed). If I understand the theory correctly I have to make a antenna that resonates with this frequency, and from the looks of it it'll be a untuned antenna, correct? And also if the water's conductivity is low, this means the dipole will be larger. Im having trouble figuring out what shape and length to use. I looked up a dipole antenna but making a dipole antenna is impractical (1,600 ft long). If someone could point me in the right direction of tell me the kind of shape that'd be great.
