DIP Lead straightener
Discussion in 'General Electronics Chat' started by mcgyvr, Aug 29, 2012.
  1. mcgyvr
    Thread Starter AAC Fanatic!
    Oct 15, 2009
    4,791
    976
    Anybody use one of these cheap DIP lead formers/straighteners or similar before?
    http://www.all-spec.com/products/FT100.html
    Do they work well?
    I'm going to be inserting a bunch of 16 pin DIP opamps and thought it would really help during insertion.. I hate having to press them in pin by pin straightening as I go..
  2. paulktreg
    Distinguished Member
    Jun 2, 2008
    624
    125
    I've used them and they work but it's usually enough to press all 8 pins down at once onto a flat worktop?
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
    I'm all about speed man..speed..;) The one I linked to attaches right to the IC tube.. Slide it out with your finger right through the wheels and go.
    Very glad to know they do work properly though.. I just talked to another person that said they work great too.. I'm buying it.. Can't go wrong for $30..
  4. Markd77
    Sep 7, 2009
    2,803
    594
  5. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    DIP leads are splayed (spread apart uniformly) to hold them in place for wave soldering. The auto-stuff machine slides over the leads to align them with the PCB holes when stuffing but there is enough springiness in the lead-form to cause the leads to spring out again and provide some grip to keep the DIP from floating out or being washed out of the holes when their underside is hit by the solder wave. It also helps keep the components in the board while its being moved about in the system.
    As noted, I use the anti-static benchtop to roll the leads parallel for hand insertion but you can buy something like this as well. I DO like the gadget referenced above.
  6. W4GNS
    Member
    Dec 1, 2008
    17
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    For new ICs I roll them on the bench top.
    For leads that get bent removing an IC from a socket (it could happen!). I use a pair of bent nose pliers
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It's just as easy and fast to use an IC insertion tool. The advantage is that the IC leads will still slightly spring outwards when you release them, and keep them snugly seated.
    If I don't have an insertion tool handy, I'll roll them on the bench.
