Hello Everyone,
I'm brand new to your forum and learning about electronics by reading and building circuits. I have a beginners question regarding diodes. I have put together a circuit that I found here:
http://www.ecircuitslab.com/2011/06/555-timer-circuit-with-variable-onoff.html
I cannot get it to work although I have rechecked it multiple times. Using an LED there is voltage at all times at pin 3, which I can vary with either pot, but not get it to switch.
The circuit requires 1N914 diodes but I used 1N4003, which I had from another project. Is it possible that the diodes are at fault. I would appreciate your opinion.
Thanks - Geoff
Thanks - Geoff
