Diodes
Discussion in 'General Electronics Chat' started by krgoutham, Jul 27, 2006.
  1. krgoutham
    Dec 8, 2004
    22
    Hello
    Are there any diodes available in the market that are better than the conventional ones. FOr eg, the commercially avaialble diodes have a drop of 0.3 volts. Are there any diodes available that have a much lesser voltage drop.
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    What sort of forward voltage drop are you requiring?
    It is usually Germanium diodes that have a voltage drop of about 0.3V and I have heard of some having forward voltage drops of down to 0.2V. However, it is primarily material dependant.
    Dave
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  4. BladeSabre
    Aug 11, 2005
    105
    I'm using BAT754 Schottky diodes, which have a forward voltage drop of 0.2V (at very small currents only). I've not come across anything better than that.
  5. Ron H
    Apr 14, 2005
    7,050
    657
    What are you using them for? There are feedback circuits (and feed-forward circuits) that, in some applications, can reduce the forward drop to essentially zero.
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
  7. BladeSabre
    Aug 11, 2005
    105
    Protection circuits for chips where the inputs can't go below -0.3V. I'd be very interested to hear about that though.
    "100's of mV" >= 0.2V
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Ignore my stupidity! I was thinking that the MOS technology had forward voltages in the region of 100's of micro-volts. As it happens I can't read or type.
    Dave
