AS you got the email, it seems it went alright. If it turns up, then OK. If it doesn't by tomorrow, give me a PM and I'll redo it. I replied direct from my email box so didn't keep a copy.Originally posted by Sheldon@Jun 2 2005, 07:49 PM
looks like it has, although the board just might be slow, as I got an email to say you'd replied to this thread and your message took a while to appear.
[post=8163]Quoted post[/post]
I'm pleased it's all working OK.Originally posted by Sheldon@Jun 16 2005, 11:05 PM
Enclosed is the diagram to give you an idea of how it works incase your interested, its not accurate symbol wise I've just knocked it together.
[post=8580]Quoted post[/post]
pebe.
[post=8582]Quoted post[/post]
You're always most welcome. Yes, I got your PM. I should have acked. Very remiss of me. Sorry.Originally posted by Sheldon@Jun 17 2005, 11:23 AM
Did you get my PM? Thanks for all your help BTW.
[post=8590]Quoted post[/post]
Diodes are rated for both voltage and current. You have already supplied the voltage used in your particular application. Does the diode you are replacing have any markings on it? What does it look like?Originally posted by Sheldon@May 29 2005, 07:11 AM
I'm looking for some diodes for use in automotive circuits, but havent got a clue about the specification side of a diode; does the diode have to be specifically for 12V? Or can you use any diode rated above 12V? Is there a specific part number/type/make......?
Any help would be appreciated.
[post=8030]Quoted post[/post]
I forgot to include something in my reply to your question. You can always use a diode with higher voltage ratings as long as the diode will handle the amount of current for your particular application.Originally posted by pinball8@Jun 19 2005, 05:08 AM
[post=8610]Quoted post[/post]
Thread starter | Similar threads | Forum | Replies | Date |
M | Different readings when testing a diode on-board and off-board | Test & Measurement | 4 | |
G | LTSpice solar panel, trouble with bypass diodes | PCB Layout , EDA & Simulations | 10 | |
A | Control or diodes? | General Electronics Chat | 25 | |
J | Diodes and Voltage Measurements | General Electronics Chat | 31 | |
J | Common Diodes | General Electronics Chat | 12 |
by Aaron Carman
by Aaron Carman
by Aaron Carman
