A wire is a component. The current cannot go through ANY component more than once.couldnt the current go through it then through the resistor and to the negative terminal?
ohhh so D3,D2,D1 would ALL be reversed biased and have a zero current then?A wire is a component. The current cannot go through ANY component more than once.
Correct.ohhh so D3,D2,D1 would ALL be reversed biased and have a zero current then?
Correct.D4 has the most current and D1, D2 and D3 has the least at 0 current
Would they? Why?if we reversed it then D1 and D4 would both have the same and most current
If the voltage difference between the top rail and the bottom rail is V0, what is the voltage across each diode in the string with two diodes and what is the voltage across each diode in the string with three diodes?I figured that if it was reversed the current would flow equally to both D1 and D4 but I guess it would flow more towards D4?
I dont understand why this is though, the resistor is before both D1 and D4
Why? Or, more to the point, how could it be the same?first the voltage would be the same for D1 and D4 would it not?
D5 and D6 have the same current by symmetry. They are identical diodes and have the same voltage across them because they are in parallel, so they have to have the same current though them. D1 and D4 are NOT in parallel (there is nothing forcing them to have the same voltage across them).well before we stated D5 and D6 were the same current, so I thought since D1 was revered now D1 and D4 would be the same.
Correct. So D4 would have more voltage across it than D1. What does that mean about the currents?if there is 3 in series compared to 2 in series the 2 would get more voltage I would assume since there is less diodes in series
D4 also has more current than D1D5 and D6 have the same current by symmetry. They are identical diodes and have the same voltage across them because they are in parallel, so they have to have the same current though them. D1 and D4 are NOT in parallel (there is nothing forcing them to have the same voltage across them).
Correct.D4 also has more current than D1
Thread starter | Similar threads | Forum | Replies | Date |
M | Different readings when testing a diode on-board and off-board | Test & Measurement | 4 | |
G | LTSpice solar panel, trouble with bypass diodes | PCB Layout , EDA & Simulations | 10 | |
A | Control or diodes? | General Electronics Chat | 25 | |
J | Diodes and Voltage Measurements | General Electronics Chat | 31 | |
J | Common Diodes | General Electronics Chat | 12 |
