Diodes
Discussion in 'Homework Help' started by TL314, Apr 7, 2015.
  1. TL314
    Mar 29, 2015
    64
    solved
  2. joeyd999
    Jun 6, 2011
    2,757
    2,937
    I won't comment on your conclusion, but your analysis is *completely* wrong. Study the diagram carefully! The answer is evident by inspection.
  3. Jony130
    Feb 17, 2009
    3,993
    1,116
    Try again but this time use D1, D2... instead of " first diode and the last diode".
  4. TL314
    Mar 29, 2015
    64
    Sorry I may still be *completely* wrong but I meant D4 as my first diode and D1 as my last.
    Or from most to least current : D4, (D5,D6)(same), D3, D2, D1
    is my analysis still wrong?
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The picture is so small, it can hardly be read.
    Bertus
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    Are you trying to say that the current will flow through D1?
  7. joeyd999
    Jun 6, 2011
    2,757
    2,937
    You got the first part right....but you need to examine the network D1..D3 more closely.
  8. TL314
    Mar 29, 2015
    64
    it wouldnt?
  9. TL314
    Mar 29, 2015
    64
    I dont understand?
    current in D3 > D2 > D1... since the resistors are there its restricting the current going to D2 and then again to D1
  10. djsfantasi
    Apr 11, 2010
    2,911
    881
    Take a hint from my avatar and "Look Carefully".
  11. WBahn
    Mar 31, 2012
    18,088
    4,917
    You seem to be saying that the current that goes through D1 (the "last" diode) has to first go through all of the other diodes and resistors. Is that really what you are saying?
  12. TL314
    Mar 29, 2015
    64
    It has to go thru the first resistor and D4 D5 and D6 then the resistors around D3 D2
    oh would that make D3 and D2 current the same as well? the resistor current flows around them straight to D1?
  13. WBahn
    Mar 31, 2012
    18,088
    4,917
    When the resistance is infinite, it's as though the resistor isn't there. Under those conditions, how much current is flowing in the diode? As the resistance decreases, what happens to the diode current?
    So if I have two of these circuits in series (so that both have Io going through them), and the resistance of the first is smaller than the resistance of the second, which diode has more current flowing in it?
    With this in mind, and thinking only of the branch with D1, D2, and D3 in it, which of these three diodes has the most current? Call that Dx.
    Now do a similar analysis thinking only of the branch with D4, D5, and D6 to find which of those three will have the most current in it. Call that Dy.
    Now the only question is which diode, Dx or Dy, has more current in it. To explore this, first ask what the answer would be if the two resistors in the first branch were make open circuits (i.e., made infinite resistance). Now ask what the answer would be if those two resistors were made shorts (i.e., zero resistance). If you get the same answer in both cases, the you have your answer. But if you don't get the same answer, then that means that there is some non-zero, non-infinite value of those resistors that would result in the current in Dx and Dy being the same and if you increase those resistances then one diode has more current and if you decrease them then the other diode has more current.
  14. WBahn
    Mar 31, 2012
    18,088
    4,917
    If the current flows out of the positive terminal of the battery, then over and through D4, D5, and D6, and then up through the branch that has D3, and D2, how does that current ever get to the negative terminal of the battery?
    Remember, the current in any component in a circuit must be part of a complete, closed loop that only goes through any given component in that loop once.
  15. TL314
    Mar 29, 2015
    64
    All of the current, diode current drops
    wouldnt it be the first?
  16. TL314
    Mar 29, 2015
    64
    would the current in D1 just go back thru D4 D5 and D6 to get back to negative?
  17. WBahn
    Mar 31, 2012
    18,088
    4,917
    But if the current goes through D4,D5,D6 and then through D1,D2,D3 and then back through D4,D5,D6 it will have gone through come of those components more than once, right?
    Why, after going through D4, D5, and D6, would it not simply go straight to the negative terminal of the battery?
    Ask yourself which of those diodes, if any, are going to be forward biased and which of those diodes, if any, are going to be reverse-biased.
  18. TL314
    Mar 29, 2015
    64
    D1 and D2 would be reverse-biased I guess the rest forward biased
  19. WBahn
    Mar 31, 2012
    18,088
    4,917
    Why would D3 be forward biased?
  20. TL314
    Mar 29, 2015
    64
    couldnt the current go through it then through the resistor and to the negative terminal?
