Diodes for transients
Discussion in 'General Electronics Chat' started by shortbus, Jul 20, 2015.
  1. shortbus
    Thread Starter AAC Fanatic!
    Sep 30, 2009
    4,096
    1,692
    When should diodes be used in a circuit to suppress transient voltages? And when used, what are the selection criteria? Or should you just add one for good luck in any circuit?
  2. #12
    Nov 30, 2010
    16,705
    7,355
    Pretty wide question. It mostly depends on how sensitive the parts are. Start with input protectors for MCUs and maybe op-amps. "Small" is the word for that application. 1N4148 or a low current Shottky. We recently had a thread about using a diode connected jfet because it has such low leakage current (pico amps). The datasheet says a nanoamp, but real world measurements were in the pico range. Dump the positive surges into the power supply and dump the negative surges into common. In a car, a zener across the input power lines after some sort of resistance or impedance. Once upon a time, I used a small transformer secondary for an inductor. When inductors live in the same neighborhood, the current through the inductor is the surge rating for your diode. When the input is a small transformer, the impedance of the transformer is pretty good protection except for lightning strikes and primary to secondary capacitive coupling. That's where you can place a much larger capacitance like 0.1 uf from the secondary to neutral, or a TVS from each powered line to neutral on the primary.
    Wide question, this is not all the answers.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    Are you asking about diodes used as snubbers around inductive loads that are being switched?
  4. shortbus
    Sep 30, 2009
    4,096
    1,692
    Thanks guy's, this has to do with the 'logic' circuit for my electrical discharge machine. Ronv was helping me and his circuits had reverse biased diodes in the logic circuit. Since seeing them I've noticed other circuits posted online that have them. My circuit has only logic(4xxx series) and 3 half bridge drivers and the mosfets. Where I see them there is either an inductor, relay or motor in the circuit. What I'm doing and most logic type circuits don't use them.
    So was wondering when and how to use them.
