diode
t_n_k
Joined Mar 6, 2009
5,455
Are you thinking of the commonly used practice of drawing the equivalent circuit of a transistor as two back-to-back diodes with the base as the common connection point?
hobbyist
Joined Aug 10, 2008
892
It looks like the collector of an NPN is conected to a relay coil, so I would think maybe to prevent inductive kick back, from flowing back into the transistor, this diode will bypass the inductive spike around the transistor to ground.
Usualy a diode is put across the relay coil itself, to prevent this.
Audioguru
Joined Dec 20, 2007
11,248
I agree that the negative schematic can barely be seen, even when I make a negative of it. It has lines all over the place.
The diode across the collector and emitter of the transistor does nothing and can be removed. The diode across the relay coil arrests its high voltage spike.
