diode to eliminate transients
Discussion in 'General Electronics Chat' started by EEDude, Jun 28, 2012.
  1. EEDude
    Thread Starter Active Member
    Nov 18, 2008
    40
    I'm doing some automated testing of semiconductor devices. Some devices are intermittently being damaged due to transient spikes from the mux/ps.
    The devices are biased at 10mV and break down at a voltage around 300mV. Would adding a schotsky diode do the trick?
    Most of the diodes I see don't have bdv that low, do they have diodes with a .3V bd? Thanks.
  2. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Browsing thru Digikey I found a Schottky with a drop of 220mV @ 1A that may work by itself for you: UPS115UE3/TR7 Microsemi (just one of many).
  3. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    This could be anything, not a clear post which is possible to answer.
  4. EEDude
    Nov 18, 2008
    40
    Why would I give out confidential information on here about my company?
    Sounds pretty clear to me. Device breaks down around 300mV so need something to block 300mV and above.
  5. #12
    Nov 30, 2010
    16,684
    7,322
    I would agree that building devices that "break down" (fail?) at .3 volts would be a secret. That is certainly cutting edge technology.
